Nissan Skyline GT-R33 by Ero ;p
Re: Nissan Skyline GT-R33 by Ero ;p
Ty carbonový kravinky v interiéru se dají někde splašit, nebo je to dělaný na zakázku?Dík
Mitsubishi 3000GT VR4 in progress
To ti mozem zystit...lebo uz to tam bolo ked sa kupovalo auto.mira píše:Ty carbonový kravinky v interiéru se dají někde splašit, nebo je to dělaný na zakázku?Dík
Taaakze konecne mi moj diler poslal zoznam vecy co predchadzajuca firma urobila doteraz. Neje to ziadna slava ale tak je to len zaciatok 8)
Engine:
Block has been bored to run 87mm pistons so displacement will be around/over 2.7L
Early R32 Block (Strongest Nissan made)
Block processed by Zentani Japan
HKS 87mm forged piston kit (Brand new)
Corillo forged Rods (Brand New)
Balanced/lightened Crank
ACL race bearings (Brand New)
JUN oil pump
Sump extension ???
Adjustable pulleys
ATI crank damper pulley ??? (still deciding whether to fit this)
Kevlar timing belt (Brand New)
T88 34D Turbo kit (Brand New)
Trust stainless steel manifold (Brand New)
Trust Racing external wastegate (Brand New)
Tomei 290/280 cams with 11.5 Lift!! (Brand New)
Full extensively modified Head from Japan done by Zenatani (Tuner has never
seen such a heavily modified head before- really awesome work)
Brand New Bronze valve guides (Brand New)
HKS or a Tomei Gasket kit (Brand New)
HKS FCON PRO ECU
OS Giken Twin Plate Clutch (New pressure plates)
1000cc Injectors (Brand New)
Tomei or HKS fuel Rail (Brand New)
Twin Fuel Pumps (Brand New)
NISMO adjustable fuel Regulator
GReddy Radiator
A/M intercooler
Hard piping kit
HKS super Dragger exhaust
Suspension/Brakes:
Was an Auto craft Track car in Japan, I'm told the Handling is amazing.
K Sport 8 pot callipers! 355mm discs
Mintex Pads
Rear are standard brakes with aftermarket rotors and pads Painted to match
front brakes
JIC suspension adjustable
TOP secret Strut brace
Interior:
Front 2 Bride Bucket seats Red/Black leather (Brand New)
Rear seats Re trimmed in Black/red leather (Brand New)
Door cards Re trimmed (Brand New)
Greddy gauges (Memory version)
Nismo Clocks (Brand New)
Full roll cage (Brand New)
Exterior:
Fully Resprayed (Excellent Job) (Brand New)
DO Luck front and rear Bumper (Brand New)
CF bonnet (Brand New)
NISMO LM500 GT 18" - 10.5 J (limited number made)
Toyo triple 8 tyres (Brand New)
Nechce sa mi to prekladat ale tak si myslim ze to prekladat ani netreba
Stredu alebo vo stvrtok uz mame ist po auticko, tak to potom nafotim
Engine:
JUN oil pump
Sump extension ???
Adjustable pulleys
HKS FCON PRO ECU
GReddy Radiator
A/M intercooler
Hard piping kit
Suspension/Brakes:
Mintex Pads
front brakes
Interior:
Exterior:
Taaakze mam tu nejake new fotecky...neje toho sice moc ...ale snazil som sa pofotit co najviac dielcov z casti motora...hlavne HLAVU ktora je upravena na silu az 1600 koni!!!!(upravovana v japonsku...klobuk dole)
Hlavicka ;p
Podobne Turbo budem mat...toto je fotene z skyline GTR32 cca 900 koni.
Moj ma byt od znacky Trust z max fukanim 2.2 BAR.
ECU
Lepsie fotky som nemohol urobit zvonku ...lebo ako vidite je teraz v garazi a vytlacat na dazd sa mi ho nechcelo ;p
Blok motora ma dojst do 2 tyzdnov... je na vybruse a dalsie dielce nafotim cez vikend ked bude viac casu.
Hlavicka ;p
ECU
Hezky nás tu zásobuješ fotkama
alespoň je na co koukat. Kdy by to mělo být připravené k provozu?
jj:p ...mno hotove by to malo byt tak o 3 mesiace...neplasim sa nikde ...radsej pomalicky a kvalitne vsetko urobit a premysliet nez na rychloa dosrat toSpeedy píše:Hezky nás tu zásobuješ fotkamaalespoň je na co koukat. Kdy by to mělo být připravené k provozu?
Tak a mam tu dalsie fotecky
HKS DRAGER
Imho peknej komin
Nakoniec sme ho vytiahli von z garaze aby som porobil viac foto...skoda ze je z vonku od prachu
Tie brzdy su nebezpecne.... 8)
NISMO RULEZ
Nak moc ne? :pimp:
Kapota cela z Karbonu
HKS DRAGER
Imho peknej komin
NISMO RULEZ
Nak moc ne? :pimp:
nebudeme porad chvalit a pockame si na dalsi upravy
Jinak vsecko moc hezke
Tak dalsie vecy su uz objednane z Japonska...ale to este nieje koniec !!!
Here are a list of parts for your Monster GTR that will be ordered from Japan:
Trust T88-34D Full Turbo Kit with racing External wastgate (Very loud when on boost!!)
Fuel rail (Make TBC)
1000cc injectors (Make TBC)
Tomei Head gasket 1.2mm
Fuel pump (either Bosh or HKS)
Cam belt (Make TBC)
This is all I can think of at the moment
Cam belt (Make TBC)
Takze mame tu "mensiu" zmenuEro píše:
Tak som sa najebal a rozhodol ze tam vlozime najsilnejsie turbo od Trust T88 series.
Takze bude tam fukat: TRUST T88-38GK turbine (polished) biggest in T88 series ...s tymto turbom je mozne, ze nam vykon vyskoci aj cez 1000 koni..no nechame sa prekvapit potom na brzde muhehe
a bude to hucat asi takto ( je tam to iste turbo a vykon tejto supry je 967 Koni !!!:
http://www.youtube.com/watch?v=2du3Ok6D ... Supra.html
